I put my inline pump in and the diagram they gave me told me to just hook it up to a hot and ground. Well it wont turn off and will spike lean at times. Well i made a call and thay sent me the wrong diagram. I need a pic where is my Trigger switch for the intank pump that i need to tap into with my inline need asap
you'll need to run a hott and a ground from the battery to the fuel pump. you'll also need to get a inline fuse and a Relay that is setup for the proper amperage. You'll wire that inline between the Hot wire on going to the fuel pump. then run the "switching" power from the Hott wire going to the fuel pump in the trunk compartment...
I want a diagram Becouse we really dont want to run a wire all the way back. I want to just go in the finder with the rest. So i need to track it down
