Need a new steering rack
det_riot
Dearborn
So I found out that my steering rack has been leaking all winter =/ which means that its time to get a replacement. What are good brands to look for that won't break my bank? I don't auto cross so a super high performance one isn't necessary. Thanks inadvance guys!
det_riot
det_riot
Dearborn
How much did that end up running you? Is a cobra one any better than stock?
SRT Handz
03 Cobra rack is supposed to be Valved stiffer and have a better feel. I bought mine for $125. Had 12,000 Miles on it. Was very clean when i got it.
I also installed Poly rack bushings at the same time.
det_riot
det_riot
Dearborn
det_riot
det_riot
Dearborn
So I found a deal for an 04 steering rack and pinion and steering shaft. Is the steering shaft on 04 cobra's any different than stock ones???
ReplicaR
javi said:
I believe cobra and mach 1 racks are the same?
They are not the same. 02-04 GTs and Mach I share the same rack, V6 has their own rack, and Cobra has the one with the least assist for sportier feel. I actually posted dot-matrix codes on how you can differentiate the racks from each other earlier on, you can search for that if you'd like.
People say that 03-04 Cobra shafts have a poly urethane rag joint. I have one sitting in the garage and a regular shaft next to it, and I swear, I can not tell a difference.
det_riot
det_riot
Dearborn
hmmmmm is 75 bones for a shaft a good deal?
wytstang
I've heard/read the same thing. I think I paid $100 for mine new.
