Need help ASAP!!
94GTMike
ok well i jsut put cobra 1.7 roller rockers the explorer manifold and all that and now my car is making a weird sound. i cant tell where its comming from.
heres some pics and a video of what i did and what its doin? can you guys help me out and try to find out what it is.
wayne94mustang
did you spray carb cleaner around the intake gaskets (upper and lower?) to see if you have a leak?
if it revs up you have a leak
are the valves set right?
whats the timing set at?
94GTMike
ok i found out what it was. apparently the spacer i had was different then the explorer manifold so there was one port the was jsut straight open. so i plugged it up and now it sounds alot better but its hell of alot slower now for some odd reason.
oh and for some reason eventhoguh everythign is hooked up and everythign is full the low coolant light is on now.
Rice_slayer
Sounds like that things got a nice cam in it at least :p. I get a low coolant light too every now and then, but it goes off after 10 seconds, probably a faulty sensor...
Venom351R
Maine
damn thing sounded like a lawn mower :hammer:
at least you figured out what the issue was
94GTMike
yeah figures it out but why does the car run a hell of alot slower then before?
ripper
Give your puter a chance to catch up with the changes. It's probubly runnin rich Mike. All that extra air and the puter wants to dump fuel in there. Can you smell it?
94GTMike
no it doesnt smell like its runnign rich.
one of my buddies told me the opposite. he said i might need to get a bigger throttle body and injectors.
LAFENATU
No.
Stock injectors at a 90% duty cycle can handle almost 300 RWHP.
I am sure your fine.
94GTMike
hmm. wonder if i have a vacuum leak or something. like the car idles nice but when i put it in gear and try to go it pretty much falls on its face and the car will go up in rpms but just feels alot slower then stock.
94GTMike
still having this problem. let the car sit for 15-20 minutes to let the computer adjust. drove ti around and still jsut falls on its face.
1st gear bogs and then slowly gains power from 1500rpm's to 2500 then falls flat. then all the other gears jsut have no power.
i do have a bigger MAF that my buddy gave me (not sure on the size but its bigger then stock).
my other buddy is content that its my throttle body.
i jsut want it to run batter then it does now.
i followed the instructions on this page the only thing different is i have a 1" spacer
http://www.allfordmustangs.com/Detailed/614.shtml
anyone have any idea.
wayne94mustang
94GTMike said:
no i havent tried spraying anything.
valves are good.
timing is at TDC
ok, spray carb cleaner around all the gasket areas and if it revs up you have a leak
if your timing is set at 0 tdc it is retarted and you need to get a timing gun and learn how to use it
94GTMike
i will have to try the carb cleaner.
i know how to use a timing gun jsut didnt have one at the moment.
94GTMike
ok my timing is at 0 on the TIME mark.
i just tried spraying carb cleaner all over the place in the engine bay and did not get any revs.
