need help clearance question?
tommybunz
ok, i had the hardest time putting my motor back in w/ the 1 3/4 mac longtubes. after i got it back in i found that i cant get my clutch cable go in without being to close, hell i cant get the cable through the hole in the bellhousing. guys i need a pic or something to help please :dontknow:
Addermk2
are you using FOX LT's or SN LT's
typically the mac headers have clearance issues when you try to cross the model year boundries. the fox and SN had the clutch fork in different locations
T
tommybunz
not taking those things out hell getting them in motor is already in and bolted so i'll figure something out
Addermk2
I could have those headers swapped in an hour... stop being such a baby!
94-5.0GT
or if you really want you could swap clutch forks? lol just swap the headers
94-5.0GT
an the sn clutch fork is longer then the fox, found that one out when i was doing my clutch. i have tremec 3550, fox bellhousing, fox clutch fork
Addermk2
you cannot just "swap the clutch forks" he would need the fox bellhousing as well. the fox one wont stick out far enough to be useable
T
tommybunz
thanks guys i figured it out rerouted my clutch cable used a zip tie for added cleance and its perfect
