Need help fast!!!
KillaCobra
I was reversing out of a parking space and accidentally floored it, after that it bogged down. Now everytime I start it, it'll rev up to 2k rpm then drop right down and die.
I'm stuck in a parking lot and have no clue what's going on, not the iac I know for sure.
Please help!
forcefedhatch
Dirt may have moved from the tank bottom and gotten into the pick up.. Seems to be a fuel issue..also If it jumps to 2k check for vacuum leaks as well..check throttle linkage, it could be choking you out per flooding it before it gets spark
Sent from my iPhone
forcefedhatch
Check the maf as well.. It may have been jarred around, or come unplugged
Sent from my iPhone
joekd
Ct
Look at the simple things first, is the plug on top of the MAF plugged in? Do you have a cold air intake? If so is the line from the CAI to the IAC disconnected?
forcefedhatch
Oh and the inertia switch behind the left tail light, make sure it's ok and if tripped reset it.. That'll kill it right now!
Sent from my iPhone
