NEED HELP W. REAR??
J
jc95gt
would an 04 cobra irs go onto my car
what modifications would need to be done
ill just stick w. and 8.8 sra lol
its easier that way
19mustang95
JC_SapphireBlue_GT said:
or the previous owner blew the 8.8in and swapped in a 7.5in rear, but i doubt that because they would of had to change the housing and everything which would be more expensive than just replacing the 8.8
change the housing? all you do is put the entire rear into the car. much easier than rebuilding the 8.8 already suppose to be in the car, and much cheaper than buying a new 8.8
dafizuck
I swapped my sra for an 01 irs... but I had a 8.8 haha. Good luck though
2slo95fiveoh
Lawrence, Kansas
its easier that way
I have a complete 8.8 rear from a 95 GT if you're interested.. I can't remember what factory gears it has..
Brake rotors, calipers... everything.. PM me if you're interested.
J
jc95gt
will the 28 spline axles i bought for the 8.8 i thought i had interchange with the 7.5in axles?
i heard that they are interchangable and so are the bearing and seals too
uncltrvlnmatt
Pa.
If you want info on the IRS swap, talk to scareface. He has done it a few times. From what I gather talking to him about it, it is alot more than just a bolt in operation.
Probably just better off swaping out for a complete 8.8.
2slo95fiveoh
Lawrence, Kansas
The stock 8.8 axles and gt brakes are the same in the 7.5 rears. I would then assume that the
outer axle bearings and axle seals would be the same as well
Depending on the plans for your car you can build a pretty strong rear end for not too much money. I picked up an almost new 03 Cobra diff for like $150, new Moser 31 spline axles for around $220 and my gears were $40. Then just find someone to hook you up with an install.
J
jc95gt
well today me and my dad were going to finish chagning my axles since one was bent...
and another problem came along
we needed to get the pinion shaft out so wecould push the axles into the differential to remove the "C" clamps and couldnt get the pinion shaft out...we were lost for a good 15 minutes until we realized the pinion shaft bolt broke off which is very common and a huge pain in the a**
the only way to get it off while the differential is under the car is with a kit like this and you can take the whole rear down to work on this without removing the axles so we were screwed...
this is the kit you will need if this ever happens to you, i got mine from matco tools
http://www.etoolcart.com/fabbri-differential-pinion-shaft-lock-bolt-extractor-kit.aspx
so my dad called up his buddy the drives a matco tool truck, he travels all over maryland and we were fortunate enough that he was about 20 minutes from my house when we called, so the matco driver came all the way to my house for a personal delivery since we couldnt go to him because my car was in pieces lol, so that was a huge help...
after we got the tool, the bolt came out in a matter of 5 minutes lol, sooooooo easy with the tool
then we started on the assembly of the new axles/bearings/seals and all that was a cake walk
then we knew we needed a new bolt so we had to get a friend to lend us their car so we could go to plaza ford and get a new pinion shaft bolt and they had 3 in stock...woohoo, so we get there and paid 3.18 for a new bolt and finished up the job w. ease
i was going to take pictures of this whole process and what we did and make a "how to" but had no time because i had to be at work at 3 lol so i didnt get a chance to take pictures
but my rear is back together and no more squeaking while i dirve and no more wheel wobble its perfect lol
we were in such a hurry but when we got to ford they had a GT500KR SUPER SNAKE so i had to take a few quick shots lol
im just happy its all over and it works good now minus the fact its a 7.5" rear w. the t-loc cause it doesnt have clutches in it hahaha
but ill do all that another time
J
jc95gt
has anyone else had the problem of breaking the pinion shaft locking bolt?
i kno im not the only one
