Need help with fuel pump system
97NYstanGT
I'll try to be short with this
My fuel pump stopped working, I got another fuel pump from a member on NYM forum, installed it but there's still no power at the pump. Next morning I found a blown fuse which i though was a fuel pump fuse, I pulled the plug off the pump, put another fuse in, blew it again. Through hours of googling and reading on forums I figured that it's the fuel pump relay in CCRM. Got a new relay, popped the old one out, soldered a new one in, put everything back together, and put a new fuse in. The car started like a charm but only for about a second. Then I found out that the fuse that kept burning is for EEC, according to the manual it's responsible for CCRM and PCM. From what I found out PCM is the ECU or at least it's in the same location.
I got a couple of replies on mustangforums and now it's like the thread doesn't exist for them, please help me out here, my car's been dead for 2 weeks already
hlinar
Same symptoms as me. I jus tparked it almost a year ago and hadn't messed with it.
Intermittant power to the inertia switch, sometimes starts, sometimes not. for a while it would wait 6 hrs and start. other times it wouldnt prime. dont feel like rewiring or chasing it upline.
If you Do find a cure please let me know? Thx. [email protected]
duff daddy
Get a wiring diagram, and find the circuits which are related to the fuel pump. There may be a short in a connector, a module or in the wiring its self.
