Need help
Squibbyz
Tennessee
I have a 94 5.0 with 35k miles. Just bought it. When I’m driving down the road and let off the throttle the rpm’s do not drop. And they only come down as the speed drops and when I go from park to reverse or drive to reverse or reverse to drive it sometimes stalls or almost stalls. Any idea what could be causing this. Could it be one problem or two separate issues. Thank you for any help I can get. Do not want to throw money at it that’s not going to fix it
evilcw311
Most Evil Member!
Louisville, KY
Do a smoke test to check for vacuum leaks and clean your iac really good then re oil the spring a little.
Report back afterwards and hopefully with good news!!!!! [emoji6]
Squibbyz
Squibbyz
Tennessee
Will do. It will be a couple of days but will let you know what happens
Squibbyz
Squibbyz
Tennessee
Did the smoke test today and found no leaks. No codes either. Haven’t had the time to clean the iac yet. Will work on that Monday. I did a little reading and someone said they replaced the pcv valve for a similar issue and it fixed it. Is that something I should check also?
evilcw311
Most Evil Member!
Louisville, KY
Start with the iac next. Pcv generally doesn’t cause rpm’s to hang.
