Need some help guys...
Downshift
Alright here's the deal. 94 gt 5 speed. When I first start my car the Rpms go up when it fires up like normal but lately they will come down and the car will die unless I give it a little gas. It will continue to act up like this until I get goin down the road then It will be fine until I shut it off. Last week it started stalling every once in a while when I would push the clutch in and pull into a parking spot. Now last night it dies at a light and won't start. It just cranks over. After 5 minutes it starts I get to the next light same deal except it doesn't startfor maybe 30-40 min. I pulled the coil wire off and cranked it but couldn't see any spark. The fuel pump was priming and it had pressure in the rail. No cel I checked them while it was not starting on the side of the road. Magically it starts and was fine getting home. Any ideas Im trying to move and go to school I really need this car running right .
sounds like another dizzy problem. A Pip is about 20 bucks and you replace it yourself. A re-manned dizzy is about 120 bucks and you have a warranty
I don't think it's the TFI mainly due that they're not know to go out in the 94/95's. On the foxes yes but not these cars
det_riot
Dearborn
Try cleaning your MAF especially if you have a CAI. Mine started doing stuff like this, cleaned the MAF and it was like a brand new car!
Noobs jeez j/k
Ignition Control Module
the foxes had them mounted to the dizzy but on the 94/95's it was moved to the fender apron under the airbox
Downshift
Thanks for all the suggestions guys. It ran fine when I needed it to until this evening. I needed to move my car from the driveway to the street and it died 5 times to go 30 feet. Ugh. My buddy disconnects the vac line to the Fuel regulator and it fires up and stays running just fine. Connect the vac line and it dies immediately. Do the same thing like 3 times in a row. I put an Aeromotive Adjustable regulator on it that I cant seem to sell and it runs fine. So well see how it goes I will let you guys know in a couple days.
