Need some help with a 94 gt with fox body throttle body swap
texasdogman
I just took this car on trade and here is the problem. The car has a trickflow track heat intake installed on it. They basicly just bolted a fox body 75mm bbk throttle body to the intake with out a egr spacer. The throttle cable is also rigged up on it. they just bolted it on to one of the mounting studs for the tb with a home made bracket and left the kick down cable just hanging. The car is also a automatic. I am going to add a picture of what I have. I would appreciate any help you guys can give me. This is the first sn95 I have owned. I also need to knowwhat the difference is in the egr between this 94 and a foxbody. I am thinking I can just use a egr spacer from a fox. Here is a little list of the other mods the car has.
trck flow intake
75mm bbk fox throttle body
75mm mass air cal. for 30lb injector (with 30lbers installed)
trickflow heads
fcam
410 gears
Thanks in advance guys here is the pic sorry it a little big.
Stangbangin
Looks like they did the fox body tb swap to get them valve covers to fit better. You'll need that egr plate and get the right bracket for the kickdown cable.
