new cams
grthayer
so i just bought a set of brand new in box pi camshafts. how do i tell wich is driver side or passenger?
98mstanggt
Louisiana
I figure if you gonna install cams might as well get some aftermarket cams esp if you're paying to get them install :dontknow: not to mention more performance and that muscle car sound :thumbsup:
G
grthayer
well the reason i got these is cuz i only paid 32 bucks for them and they have never been turned in the heads. they r the frpp cams that come in the frpp heads and plus im on the way of doing the pi swap anyway, so i dont think i did to bad for $32. what you guys think. :thumbsup:
BigTang
not bad. comparing the specs of the PI cams to the stage 1 cams out there they are pretty close.
don't forget you need to pick up the cam bolts too before you start the swap.
sure you can go w/ larger cams but face it, the newest NPI motor is 10yrs old and you know you'll need springs, etc when you go w/ some of the custom cams. just because they have a low or similar lift doesn't take into account they have increased the ramp rate and other variables.
G
grthayer
yea pretty cheap rite. my car has around 70k on it now. a retired vet. in FL had it, he had 4 cars and never drove it. so i got it for 5k. u still think i need springs? the specs on the cams are .543 and .547. do anyone know the pecs of the non pi cams? i also have another set of the same cams ill let go for 100 shipped if anyone is interested. brand new also.
G
grthayer
what would be some good springs to replace mine with since im going with the bigger cam?
G
grthayer
i dont understand what you mean...load design. i found some comp beehive springs after i searched a lil bit. are those pretty good?
GDTrumbo
Nashville, TN
BigTang said:
http://crower.com/cat/domestic/ford/mustang_camshafts.shtml
frpp cams work in modded npi heads? anyone know the answer to this? whats the complete specs on these cams i'm interested in them
You may run into a problem w/ the lift. I've read that the nPI heads are set up for a max of .500" lift. The lobes may drag the the casting when the PI cams are installed/rotated. There is an area below the cam lobes that was opened up on the '99+ heads for the new PI cams. Just a "heads-up".
GT
G
grthayer
thanks for that info. ill have to chk into it. u mite have just saved me a bunch of money. thanks man
BigTang
ok, i knew there were clearance issues but did not know if it was w/ the casting or w/ the way the hardware was on the head.
what about Piston to valve clearance if you go to a cam over say .540 lift like most of the PI stage 2 cams are? since you can run the .531 exhaust lift PI cams i'm assuming the clearance issues are on the intake side up top but how about the rest of it. more or less curious about the workings of the 4.6 at this point.
Jrgunn5150
PI aftermarket cams start at .550 on both sides.
NPI heads will smack the retainer into the guide over .535 (to be safe)
Any spring made for either head will fit the other.
Jrgunn5150
PTV issues come from duration and lift @.050 not total lift. By the time a cam hit's peak lift, the piston is an inch down the bore.
G
grthayer
so to be 100% percent safe i need to get pi heads and better springs correct. this really helps guys. thanks
BigTang
I think there is some confusion over which cams you have. Do they have a part number on them? I know you said FRPP heads/cams but I immediately thought SVO heads, but that might not be the case.
I have an ad in the for sale section w/ pictures of the part numbers on my PI cams that you can reference. Mine are stock PI cams from stock replacement heads, they will work in stock nPi heads.
