???new combo???
Lebedin8654
Okay so i picked up a set of Windsor Jr. heads and a edelbrock performer intake. I would like to see 300 rwhp out of this setup. I am gonna port these heads pretty good and port the intake some too. The car is a T5 and i will also have long tubes, msd, a/c delete, smog delete, a 125 wet shot(like to break 400 on the bottle) and probably weld wheels all the way around. Does anybody know what a good cam would be for this setup, other than custom grind. I am looking to do a budget build setup.
Is this posibable or should i get a better intake?
What cam should i use?
Thanks!!!
Win
Kennesaw, Ga
I think with those heads and that Intake you will be right around the 300-315 rwhp. Especially since your going to port them thoroughly.
Paul
Porting them yourself, without knowing what you're doing, can actually cause you to lose power.
One of bigger grinds in the comp extreme energy lineup would probably work fine.
L
Lebedin8654
I am mostly gonna do a really good and deep gasket match, knock down any bends a little and polish them up! They will defiantly flow better when i am done with them!
Staff online
