new member 351 questions
351 charles
Hey guys. New to the site and I needed some help. I'm about to start building a 351 windsor motor specifically for hill climb and road racing. I'm going to bore the motor 30 over with a 4 inch stroke. This is the rotating assemblies I'm going with.
Scat Engine Rotating Assemblies 1-47353BI.
I'm looking for the best setup possible between cams, heads, and intake. Any advice would be greatly appreciated.
evilcw311
Most Evil Member!
Louisville, KY
Charles I moved this here where you lo be able to have anyone answer and not clog another’s thread.
Welcome to the forum and I’m sure you’ll be able to get lots of good answers as to what you wanna do.
Randall Garner
US NAVY
Hello. What kind of rpm you looking for. Hydraulic roller cam I assume. Do you have heads to handle. The 408 demand for good air and lots of fuel. With a 408. You'll need a cam with greater than 245 @ .050. LC AROUND 110. heads and springs will dictate lift. These engine like a lot of lift AFR, RHS, TEA, PROFILER ALL MAKE GOOD HEADS. It just depends on your budget. I run profiler in a drag car. 393w stroker. Small [email protected] cam 110 LC with .600 lift. And with 28" tires, 373 gears 3000 stall. C-6 trans. I've ran a best of 11.55 @ 118 in the qtr. Look at them all. Maybe find a wholesale shop where you can buy direct and have high quality valves and springs. Look at howard's cams. They have a wide selection for the 351 based strokers. If your road racing has short straights and a lot of curves. The edelbrock air gap is a good one. Only issue I have had is. With out porting and a 2" spacer the air gap tends to hit a wall at about 6000 rpm. The victor junior is a great choice . power nation, Built a nice 408 and it cam was nearly same as my 393. Similar heads. Same cfm carb. And it hit a wall at 5900. Just changing the intake. Gained them nearly 1000 rpm and near 100 hp. Remember a engine is just an air pump. The more efficient the better.
RevBott
