New Rear End
Adam Gustafson
Hey Guys! My posi-trac system makes a clicking noise in the rain and I am simply looking to upgrade my rear axle. I want the Ford Nine inch but I am not sure what the best gear ratio would be for my car. I drive a 99 Sn95 Base model with some minor engine upgrades CAI, BBK throttle body, and a Bama Tune. As far as other modifications I have SR Performance sway bars and Coilovers. My driving style is spirited on the back roads!
What would be the best rear gear ratios for my car! Thanks for the help.
SnakeBit!
Florida
you will get several different opinions. what type of driving do you do....daily driver, weekends, local, long distances, interstate...what or how do you use the car.
Adam Gustafson
Adam Gustafson
My car is a Weekend driver however, during a really nice week in the summer I may take it out every day for small cruises with friends in the local car community. I drive the car a lot on some of the winding back roads and would love for it to become a track (Road course) car one day
lwarrior1016
Mr. Secondary Timing Chain
Staff member
South Mississippi
What in the world makes you want to go through the trouble of swapping in a 9 inch? The 8.8 is plenty strong for about 99% of the crowd out there. If you are serious enough to "need" a 9 inch rear, then you probably dont need to be on here asking questions.
SnakeBit!
Florida
I agree with Iwarrior...the 8.8 can be made plenty stout enough to not have to go thru the expense and trouble of swapping in a 9". depending on your eventual goals with the motor, i.e., supercharge, turbo, whatever, that will also dictate your ratio. for most purposes, either a 3.73 or 4.10 will do the job. most like the 4.10's in these cars, I prefer the 3.73 having had both. if you boost, then probably 3.55.
kb1982
Kentucky
If you want to fix the issue for cheap, just change out the rear diff fluid and then add the proper amount of friction modifier.
