XxslowpokexX
Hey all,
So we have a motor going in. Let me just list the stats
Built 306
8.5:1 compression
Ported AFR 195 heads, Anderson b41 cam
Ported upper lower Cobra intake, 70mm TB,
Pro-M MAF 42lb injectors
A1000 fuel pump sumped tank etc.
Its an s995 setup.
Now I haven't built a supercharged 5.0 since about the mid 90's as I got sidetracked with turbo setups and v6's for awhile. This SC kit is kind of funky in that the TB is so close to the discharge of the SC....So an IC doesnt seem doable. Will more then likely add a meth kit later on so I can run a bit more boost.
So my main question is tuning and injector sizing. Back in the day I used the FMU's to a relative success with like a 30 lb injector. Relative in that they worked fine and I didnt blow anything up. Then the super FMU's to fine tune a bit. But now much of that can be done via tuning. I plan on running a moates QH.
Soo Are 42's enough without an fmu or do I need to go with a 60lb injector or so? Like I said it;s been awhile and I dont know what to expect power wise. Just keep in mind I already have the 42's and matching MAF..Not that I wont upgrade. But for those of you running sim setups..What do you think?
Built 306
8.5:1 compression
Its an s995 setup.
