newb engine swap question
xs man 27
my car ( 95 gt vert )may have to get the engine pulled and swap in another motor, in that case i m weighing my options on what other engine i can swap in and stilll keep my bolts ons and longtube headers , edelbrok intake manifold..etc.. i wouldnt wanna do a engine swap and not be able to use the aftermarket bolt on parts i have for budget reasons... i got a quote from a mustang salvage parts place for just under $1000 with shipping for a stock 94-95 gt motor but i m thinkin if i can find something better this is the time to do it if any.. thank you all again and helping a newb out.. take care
Musturd
Ur manifold and headers will work on any 302 based motor. Try and find a explorer motor with gt40 heads not the p ones as ur long tubes won't work
X
xs man 27
engine may need rebuilding so i was just thinkin whats the best option i should do now while the winter is here and i have months to get work done on my car.. yes stock heads, budget around 2 -3 thousand.. what are the best heads to use ? and what HP gains can i see with them ? any other advise on what what people have done with there re build engines and what components they use and HP gained .. thanks again guys..
castine917
wyoming, mi
What are your goals with your car? Why does your engine need to come out for rebuild? Leaking oil, smoking, low compression in a cylinder, rod knock........?
castine917
wyoming, mi
Do you plan to do the work or hire someone? If doing it yourself, what is your capability level?
X
xs man 27
my family member is a mechanic so i m lucky in that sense i have someone to teach me, i would like 350 - 400 hp being long time goals,, i know 350 may be more realistic.. my mechanic telling me theres a knocking sound and theres oil coming out of one of the tail pipes .. i m just weighing my options and looks like the crate motor a lot of people are not for and to rebuilt the current motor with better heads.. i m just a new b and dont know anything when it comes to boring out engines and that part of engine building.. thanks again guys for your help and input ,,, more i look at it if i need to do something with my motor now is the time to do it to have it ready for spring.. thanks again..
