no fuel??...help me please!
ryankelly10953
I have a 95 gt that i just got finished...But im not getting any fuel....when i take the bleed valve off the rails no fuel... i took the fuel pressure regulater off and turned it over no fuel....so the question is what do i need to check...fuel pump...fuse...filter...i have been bent over the hood for 3 days...no clue?? any help would be appreciated
Thanks Ryan
R
ryankelly10953
when i put a fuse in #18 it keeps popping...im pretty sure its the fusible link....where would that link be....eairler in the build i had a bad ground wire and right under the rear axle there was a little smoke...smelled like a burnt wire...please help
a bad fusable link isn't going to cause the fuse to pop. you probably have a hot wire that has chaffed through the insulation and is now shorting to ground back where you saw that puff of smoke. there is also the ineritia switch located in the trunk by the left tail light.
slopony
you have a wire grounding out some where. check the harness from the fuel pump forward and look for burnt or chaffing wires. I know its a PITA but keep looking you will find it. I had a problem on my 97 cobra of blowing the ecu fuse. come to find out my exhaust burned the the wires on the o2 sensor.
