no parking or dash lights
1Bad Snk
brake lights and head lights work...all blinkers work.....dash,tail, and front parking lights dont turn on.....ive checked all fuses...all good......any clues? my gauge cluster has been changed..not by me....dont see any obvious wires disconnected......im stumped
ram360
pull the headlight switch...sometimes the connector melts or the switch itself fails.
CanaryGT
Phoenix
+1
Just happened to mine about 6 months ago. Mine was the pigtail.
1Bad Snk
FIXED!!!! it was the headlight switch....the pigtail was a little melted also...hopefully it holds up..thanks alot guys....ive been checking fuses and wiring for a month
1Bad Snk
can i get the connector at any parts store?? just cut it off and splice in a new one?
call around and ck who has them. some do some don't.
I was able to remove the all the pins except 1 and match the color on the new connector then reinstall. only remove 1 at a time so you don't get confused. The 1 I couldn't remove I did have to cut and splice.
CanaryGT
Phoenix
I went a little further and put connectors on them because if it happens again all I have to do is pull it out and re plug the new one in...
EdgarR213
