Noise coming from clutch/tranny?
5.0 For Life
Hey guys, im looking at a 94 gt. Its a 5 speed and has a tri-ax shifter. I drove it last night and there is a noise coming from the tranny or clutch. When I take off nicely it sounds like a buzzing noise. My brothers S2000 has the same problem, and Honda said its normal for them. Does it just need a tranny flush or what could be the problem?
Thanks!!
Paul
What do you mean "buzzing" noise? Does it make the sound all the time? Clutch in? Clutch out? Neutral? Rolling? Stopped?
5.0 For Life
It only makes the noise when i let off the clutch and start rolling. Clutch in it dont make the sound, neutral it dont make the sound, not very often rolling it makes the sound and stopped dont make the sound.
By buzzing i mean, like it sounds like its buzzing. I really dont know how else to explain the sound.
Paul
Hmmm. I'm afraid I couldn't hazard an intelligent guess based off that information. The best I can say is that it sounds transmission-related since in the cases you've provided, the gears within the transmission would be turning.
Oh, and it doesn't sound normal.
5.0 For Life
Ok, im taking it to a garage tomorrow to get looked over and they do a road test, ill point out the noise to them. I hope its not too bad cuz I really have my heart set on this mustang!
Paul
Don't buy a car based on emotion. You'll be better off waiting for the right car. Trust me. I've been there.
you mean it buzz/squeaks when you let off the clutch pedal.but it doesnt do it while you have your foot on it.if soit could be the TOB.
Paul
The throwout bearing should make a pretty distinct "squeak," however, I guess describing a sound over the internet is probably pretty tough. :hammer:
If it is indeed the throwout bearing, that's a $20 part and a day's worth of work.
5.0 For Life
If I do buy the car, first thing im going to do is a tranny flush and put some royal purple syncromesh in there. Hoping that will fix the problem, if not ill try the throw out bearing idea.
Thanks alot guys, your being alot of help!
As Paul already mentioned above is not an expensive part,the problem is the labor, it could cost you anywhere from $100 to $500 depending on the shop.
Good luck keep us updated :thumb:
Jrgunn5150
Synchros commonly make a "whirring" sound, doesn't even mean they're bad, it just means put some synchromesh in it.
5.0 For Life
Alright thanks alot guys!!!
If its good ill be picking up the car on thursday and i most def will post up some pics!!! :banana:
One other question, my friend had a 89 hatch with a 5.0, it had almost 160000 miles on it. How long can a 5.0 last if its maintained very well?
Jrgunn5150
Honestly, and normally, around 200-225k. Of course every accessory will need replaced, etc. And there are some freaks running around with 400k, but don't count on that.
5.0 For Life
:TY: and I will most def. keep you guys posted, I have been dreaming of owning a mighty 5.0 for many many years, and my dream is finally coming true!
95 svt cobra
yeah if it only makes the noise when your foots off the clutch and stops when the clutch is depressed, then its def an internal tranny problem. do like you said, have a shop check it out but beware if you seem like you dunno stuff about cars they will try to rape you, go to a trusted shop and dont take any shit. :welcome:
R.C.
