O2s reading lean
94IVGT
Northcentral, IL
This started last week so I haven't been driving it and cant figure out what the issue is. My wideband and stock O2 are both stuck on lean readings 0.0-0.08v. I have swapped the O2s for original ones and same results. Fuel pressure is 45psi at idle. looks to be no issue in wiring, I pulled out the majority of that and looked it over and cleaned it up. Now im stuck with this issue I am having trouble solving.
Paul
Poor ground? Is the car running excessively hot? Do the plugs confirm an exceptionally lean condition?
when ever i got lean codes (i know you based this off your wideband) it was because my MAF needed cleaned.
Paul
Forgive me for stating the obvious here, just thinking out loud I guess...
So your O2s (both wide and narrowband) are reading lean, causing the ECU to dump lots of fuel, which is causing the plugs to indicate a rich condition... but the dumping of fuel is not changing the reading. It is unlikely that all the O2s would go bad at once. What really perplexes me is that an electrical issue (i.e. bad ground) would likely effect one set of O2s, but not both. So if the narrowbands went lean, but the wideband went rich, then you could check against the plugs to find out what was really going on, then chase down the error with the offending O2s.
So the reality is, so both sets of O2s indicate lean, then obviously you really are running lean. Has the operating temp of the car increased significantly? Have you checked signal from stuff like the ECT and MAF to ensure both are switching?
Paul.
94IVGT
Northcentral, IL
Yes it is dumping fuel. Sitting for a few seconds you can smell it even, smells like I'm runnin my snowmobile in the garage on cam2. My car has not exceded 210degrees. And I have not checked maf.
