OK as I mentioned in the "Navigator Thread" (http://sn95forums.com/index.php?topic=25571.0 for those of you that read it before) I think I got it down so far.
As most of you know reivaxtorres Who did the Double Din Bezel install write up also threw in a 04 Mach 460 6 CD changer. He was going to do a write up on it but I reciently did this upgrade too. Before you go out and grab that 05 Mustang 6 Disc MP3 Changer there's a few things you need to gather info on concerning your stang.
-Do you have Mach 460 or not?-
This is a big one as this changes which head units you can use and which you cannot. If you do NOT have Mach 460, You MUST get a HU that does NOT have the extra plug for the additional speakers. If you do you will have NO lows. This is because the main plug will handle the Highs and it Internally amps those signals it receives to the speakers. The other plug Sends non AMPed Mid/Lows to the amp and subsequently the Speakers.
In this Picture you can see all 3 plugs are there but the one i the top left has no pins. This would be the radio you would use if you did NOT have mach 460 as it only provides 4 speaker Audio.
If you find one like above WITH the pins this would be the Mach 460 unit. Ebayers like to label these as "Audiophile" units
-Which HUs can you use-
Here comes a bit of a prob. Once you know which one you want you need to get the correct HU. I will admit I jumped in head first and didn't do ENOUGH research as well. So here is where you get to learn from my mistake. There are at least a few different sizes of HUs. there are ones that are Smaller than the Bezel opening. A good way to tell if it is going to "fit" is to look at the outer edge. There SHOULD be a lip recessed from the face going around the the radio. Here look at these 2 Radios:
This one has no Lip and is too small for the Bezel opening. It was made to be held in place by a similar Rail bracket and Din Mount like the ones that holds the Setup in our 94-00 Stangs (Notice the holes on each side like the ones on the Stock radios in our 'Stangs).
This one has the lip as well as 2 mounting holes on the bottom.
You COULD make the smaller radio work but it does leave a slight gap and looks out of place. And aren't we trying to go for "Original Looking" Getting the right Radio will save you lots of hassle and wasted money. (Just so you know I got the Mach MP3 for a really good price cause the guy had no way to know if it worked. I took a Gamble and now that I KNOW it works I can re-Ebay it for more than I spent.)
There is One more HU Item I need to bring to light.
-The interface Plug.-
Ford changed the Plug on the majority of their radios around 98 and again in 04. In the pictures above I have the radios that have the 98-03 Plug. reivaxtorres used one from an 04 Mustang so he got the Newer Plug set up.
For the 98-03 Plug You will need Metra 71-1771 for NON-Mach 460 and Metra 71-5700 for Mach 460
For the 04-present Plug You will need Metra 71-5220 for NON-Mach 460 and Metra 71-5220-1 for Mach 460
Also again in 07 Ford Changed the Antenna cable and input to the radio so IF you decide to go that route be advised that you'll need the Metra 40-FD20 Antenna Adapter.
NOW once you decided on the radio you want here comes the most hardest and annoying part...
-The Wiring-
I wrote this as 94-98 because I *Think* there was a change in the radio harness (I'm not talking about the front amp harness I mean the one hard wired into the car's wiring) for 99 and 00. You 99 and 00 owners can correct me if I'm wrong.
Again from reivaxtorres' Bezel Thread.
See those 2 plugs on the right side? There's a Black one and a Gray one (The Gray one is hiding behind the tab in the Pic) that's what we'll be working with.
What you'll need is Metra 70-1770
So Let's start with NON-Mach 460 Cars.
My car was a Non Mach 460 car but it had the "Premium Sound" Option which was the under dash amp and a 4 speaker set up. Don't worry if you don't have that premium sound or not. The cars are Wired for 4 Speakers in the main harness. If you have Premium sound you can just remove the Amp Harness (and amp if you feel like it) since we are doing a complete amp bypass because the radio has that Amp Built in. You MUST bypass the amp or you will get no sound.
You have 2 Plugs you will need to wire into a single Plug.
From the Gray plug you will have 5 Wires you will be using. Don't go by what it says on the Metra Wires. Go by these Illustrations. The Pin Descriptions are correct except Pin 3 Is Audio Ground and Pin 7 is "True" Ground.
Using the Metra colors Pin 1 is the wire that is Blue with a White Stripe.
and on the 16 Pin Plug
Pin 1 on the Metra is Lt Blue with a Red Stripe.
How I'll do this is, the 1st Pin I will mark will be for the Gray 70-1770 the 2nd will be on the 71-1771. For Example I'll go Pin 8 to Pin 9 Which is Pin 8 on the Gray 70-1770 and Pin 9 on the 71-1771.
OK Got it? here goes.
Pins 1 and 2 on the 70-1770 are Unused. Pin 3 goes to Pin 11 or 16 your pick. Pin 4 70-1770 is Unused. Pin 5 goes to Pin 1. Pin 6 goes to Pin 10. Pin 7 goes to Pin 2. and Pin 8 goes to Pin 9.
What you did is set up Power, Ground, Audio Ground, Illumination/Dimmer and Memory.
That was the hardest part on that on. The Black Plug which is the Audio is pretty Straight forward. All the Pins should go where they're Listed in the Instructions on the Plugs.
For the 5220 24 Pin Interface Plug we'll use this Illustration
and it should go like this:
Pins 1 and 2 on the 70-1770 are Unused. Pin 3 goes to Pin 13 or 24 Your Pick. Pin 4 70-1770 is Unused. Pin 5 goes to Pin 3. Pin 6 goes to Pin 2. Pin 7 goes to Pin 4. and Pin 8 goes to Pin 1.
Gimme a week and I'll do the Mach 460. It's a whole different Beast so I'll have to wait til the rest of my set up comes in to do that part...
...TO be Continued.
-The Wiring-
...TO be Continued.
