oil cooler removal (94-95 cobras)
very simple, unbolt it and remove the huge tube thing with it. Then just buy the coolant hose that goes from the water pump to the heater core line. Don't forget to replace the oil filter, the next time u buy one you can get the larger GT filter. Done.
Maniak87
the hoses are re-routed from the vortech install so thats not an issue.
do i need to get a different part where the oil filter screws onto?
Maniak87
OnyxCobra said:
nope, it screws right onto the block once you remove the oil cooler.
how does that black part come off? un-bolt where the oil filter screws onto then it will just slide off?
by black part do you mean oil cooler? If so, you'll notice the part you normally screw your filter onto has a hex head, grab it with a wrench and it will unscrew the cooler from the block. It will leave you with the normal fitting for an oil filter just like all the other stangs.
Maniak87
ahhh, i see. yea, i did see that hex.
thanks for your help. i'll post again if i have trouble with it.
forcefed5pt0
charlotte nc
all 5.0 cobras have coolers, so they run the smaller oil filters unlike gt's that use the larger oil filter
Maniak87
94Pro-5.0 said:
if i were to put a cobra oil cooler on my gt, do i just swap filters or is there another mod?
i wouldnt go with the cobra one. get an aftermarket one.
Yeah don't install the Cobra oil cooler, imo it's not worth it. If you want one go with the ones like the a/c Cobras have :pimp2:
94 DropTop
what does this cooler look like cuz i think my gt has one stock.
a lot like this, it's a lil thing between the block and the oil filter.
94Pro-5.0
Little Elm, TX
oh lol, is that it? i was thingking of a large aluminum cooler. i plan to get an aftermarket one soon.
yup, s'why i decided to ditch mine. Definitely go with an aftermarket one, one that looks like a small radiator.
94 DropTop
I have this metal tube that i think is an oil cooler on my gt. it goes and mounts infront of the radiator.
Maniak87
might need a pic of this to verify what it is.
2plus2
That could be for the power steering.
These two black tubes that go from up around the tstat housing down over the waterpump to the oil filter area is what the stock cobra oil cooler uses to run coolant through it, this is how mine looked before i took it off.
