Oil Filter Clearance Issues?... Here Is the Solution!!!! *Pics*
Willis_98GT
DFW Texas
SRT Handz said:
Bump For Will :boink:
this technique worked 100% i can't believe that something honda made 20 years ago or so slides right on a 4.6 mustang motor.. lol
used a fram ph3531, will be a temporary fix until i can get some new motor mounts.
GDTrumbo
Nashville, TN
OK Willis_98GT. You have a '98 model GT. What is it's production date? My '98 does not have the large silver filter mount that yours
and Handz have in the pic's. I have a production date of 5/98. Is this a late '98 on-the-fly production change?
I also found that when I replaced the crappy "cracked" plastic intake that mine also has the '99 coolant line (style & location)
passing under the intake they spoke of in the install instructions. It states "some late production '98's have the revised '99 coolant
line" and not to bother doing some small modification to it.
I wonder what else changed during the '98 production run. Any ideas? GT
SRT Handz
the "S" in FL-820S stands for "Short", Not silicone. Thats retarded to think that once filter uses different things that other motorcraft filters.
Ford had to make a short version to fin the tight engine space...thats the only reason we use a short filter.
Steven said:
also.. why didn't you just put a new motor mount on it.. you obviously need one. It's a band aid to the situation.
If You would go back a READ instead of Assuming things you would know that i already changed my motor mounts.
http://www.sn95forums.com/forum/index.php?topic=23047.0
This fix isnt ment to be used forever but to be used till you can change the mounts. My mustangs is my only car and ONLY way of transportation to school and work.... and missing school is not an option. I really just can stop doing what i am doing to change my mounts and i need to get to school, so i engineered this fix to get me to school and back. My mounts were so shot that i couldnt even get a filter on besided the Honda filter. Thise fix helped be get thought 6 weeks so i could drive to school until my motor mounts came in the mail and i had time off to change them.
I offered this solution to Will because i know he needs to drive his car, so this will help him drive the car until he gets his mounts on.
This is Also a solution that people use when using a aftermarket k-member and need a smaller filter.
Steven
SC
sigh.. handz. Everyone, technicians, parts men, service writers, will all tell you it is not a short version. It is an updated version of the regular 820. They wouldn't call it a 820s if it was meant to be shorter, it would have a whole other part number. Find a old 820, it is no different physically outside then an 820s. I work with these things all day long, theres a friggin box sitting next to this very computer i'm on.
SRT Handz
been to several dealerships in socal and they said the same thing, S=Short.....
GDTrumbo
Nashville, TN
The only visual, physical difference between the Motorcraft FL-820 and the FL-820S is when you look down the
throat of the FL-820S you can see the "orange" colored silicone anti-drainback valve surface in the small windows
around the filter opening. The superceded FL-820 is black.
The only reason Ford might even still sell an FL-820 is if the filter mounts horizontally on that particular vehicle
and "drainback" is not an issue. Personally, I have not seen a FL-820 in years. GT
GDTrumbo
Nashville, TN
I wonder if these technicians feel that it does stand for "short" because other than the length, the filter resembles
the FL-1 from the 302/5.0L era. Even the mounting face and seal look a lot like the FL-1 from years back. Just a thought. GT
SRT Handz
maybe...... This is most likely true. I am just saying what i have been told. I Know that asking someone at a dealership isnt always gonna produce the correct answer....i know i may be wrong. It would be great to find out the exact reasoning.
GDTrumbo
Nashville, TN
Now Handz, read the quoted ^ and let me know if you have ever heard of this. It's wierd to see this
large filter mount in the pics of yours and Willis'. I know his is a '98. Is yours also?? I'm curious about the
mid-pruduction run changes as they are not always easy or cheap for mfgr's to do. GT
SRT Handz
yes, i do have the metal mount that Will has in the picture....even 99+ 2V have the same exact mount.
My 98 is a Very Late yesr production model that rolled off the assembly line on 6/8/98
GDTrumbo
Nashville, TN
OK. Then why does mine have the small filter mount? This is too wierd. I figured you would tell me
your's was produced.. like.. in january or something. Then there is the cooling line under the intake.
Mine is a '99 style. I'll have to look further into this. Thanks, GT
GDTrumbo
Nashville, TN
AaRoN said:
My car was built Feb. 1998 and it looks the same as Willis' and Greg's.
The filter on mine looks like it's closer to the block. When you loosen & drain the filter
the oil drains right down onto the rack assembly and tends to fill up, what I think, is an
adjustment nut for the pinion in the rack. GT
Outlaw97GT
Ok let a partsman of 18 years step in here.... :coolsmiley:
The "S" on the FL-820S stands for silicone as stated above, who ever told you it meant shorter is wrong period.
The FL-820 now known as part # CM6731 is now a Ford Racing filter.
http://home.earthlink.net/~cewhite3nc/id11.html
The common Ford filter you are thinking of is FL-1A which has standard threads and the new filter FL-820S has metric threads.
FYI a FL-1A will work on pre 94 small block chrysler 318,360 ect... and is longer then the stock filter.... A little info for any Mopar owners here.
SRT Handz
Good to know the real answer...damn ford parts guys are killin' me :hammer:
Outlaw97GT
Yeah you gotta be carefull with the dealer parts guys, Most (not all) are dumbass's. Ive been in commercial sales for the last 10 years so Im the guy all the shops and dealers call to get their parts.
IMO the best parts guys are in your backrooms of your local parts store.....except Autozone AKA Autojoke, votozone
O'Reilly's, Napa, Carquest ect.. I work for 1st call, O'reilly's name for their commercail dept. I don't work the counter or deal with retail customers except my friends ofcourse.
