And i hit a 15.7 in my stock 95 gt vert. i only got one run in due to that i got there late , anyone advise would help on dropping #'s, also what boltons could i buy to at least hit the low 15s high 14s thanx again guys...
Is the car an auto or manual. First things first, address any traction issue you might have. TIRES!!!
Autos are so slow ,alot of is in the tunning and the trans is a slush box a 2800 stall and 3.73 will start getting it out its own way. otherwise just change yhe exhaust and cruise it. Its hard to get results out of these years in an auto and a vert on top of that sorry to bare the bad news to ya. but if you want to get in the 14's follow this tune up plugs wires rotor cap fuel filter set timing at 12 cai off road h or x 2.5 cat back try this way first then a tune and then a gear which requires a tune ive been told and a stall good luck
ok thanx guys tmmarow im doing a full tune up on my car and bumping the timing to 12 so wish me luck at the track tommarow anything else i should do :help2:
just stick to my recipe buy good wires like a set of taylor spiral pro 8mm and no platium plugs autolites work great stick to that recipe
