Open side scoops
SonicStang
My friend has a 1994 GT and his side scoops are open, means the air goes through an oval hole in the rear fender to the tire.
Mine is 96 and my scoops are fake... anybody yet cut them open?
I've seen guys drill holes and duct the air to the rear brakes but i wouldn't do that unless i was road racing my car.
Thomas_W
Capon Bridge, WV
I've "thought" of doing this w/ my IRS setup but there isn't much room between the tire and the inner fender sheetmetal and is much more of a hassle than what it gets you.
badass98svt
It's a joke, it's more for appearance than anything. They definitely do not cool the brakes. If anything, i'd think they throw air on the tire, which would hurt performance, and in the rain would be worse as well.
94 and 95 stangs had the "functional" scoops. 96-98 did not.
Don't butcher your car up, cuz it would be worthless, unless you were to fab a hose from the duct to the center of your brake rotor.
But still rear brakes are hardly used, they don't really need to be cooled, unless you do heavy auto X.
SonicStang
Reason I was asking: I thought about getting the CDC side scoops, but I am afraid they fall off at high Autobahn speeds. Maybe with opened scoops the air flows through and the possibility of falling off would be smaller.
98vortech
i already did this.. took out the interior panels, took out the side scoops. then drilled holes in each little circle in the plastic piece. then cut a square section for the air to go through. plan on getting the 94-96 covers for the square hole.. and i also planned on getting side scoops so it did not hold back so much air..
Thomas_W
Capon Bridge, WV
post pics, as i'm interested to see how you did it. I was gonna make some CF or fiberglass ducts to direct the air to cool the rear brakes.
SonicStang
I wanna see pics, too!!!
FASTANG
I promise you this..... I too was worried about them flying off. Use 3M doubled sided
tape and they will be so stuck you would swear you'd rip the paint to the bare metal
before they let loose. DON'T FEAR THE SCOOP.
wht46gt
yeah i do some auto x mostly martin sports motor club and scca and ive gotten pics of my car with the rear brakes like almost on fire sometimes id reall like to do this simple upgrade it would help alot with the brake fade, def. need some pics of the job though
98vortech
ok guys here ya go..now dont mine the huge hole all you have to do is try and find the covers that come on the 94-95's and it will look good.
wht46gt
what are those things called that cover the wholes, how did you cut the wholes did you use a sawzaw or a cutting wheel
SonicStang
I cannot see the pics :(
98vortech
step by step
1. take out interior pieces to get to the scoops.
2. un-bolt them
3. take a drill bit that is the same size as the fake holes and drill them
4.cut you a hole in the finder. i used a jig saw
5.then bolt it back up and try to find some covers
wht46gt
do you know if theres enough room behind the wheel well to run a pipe to the back of the brakes or is there only room for just the whole
98vortech
depends on your tire size i have 315's so their is no way but after you do the cutting see if you can fab somethin up.
wht46gt
im gonna try to make somethin out of fiverglass sheating or somethin or ill just leave the whole
alleghenyamerican
