Alright guys I need some serious opinion here. Me and a friend go back and forth about the shelby cobra. He works for ford own a 96 snake nice car but knocks on the shelby. He's says it doesn't size up to the new z06. This kinda irritates me. Chevy up'd the displace of there motor to a 427 7.0 liter for crying out loud and ford matched it with a super charged 330. He says it weight more. Grant it i'll give him that but how can people argue and say it doesnt match up. I mean is it just mean or am i stupid? heres what I found
C6 Z06
Record last updated 01 / 17 / 2006
Country of origin United States
Year of introduction 2005
Introduced at 2005 NAIAS
Numbers built N/A
Body design N/A
Weight 1420 kilo / 3130.6 lbs
Engine LS7 90º V 8
Engine Location Front , longitudinally mounted
Displacement 7.011 liter / 427.8 cu in
Valvetrain 2 valves / cylinder, OHV
Fuel feed Fuel injection
Aspiration Naturally Aspirated
Gearbox Tremec 6 speed Manual
Drive Rear wheel drive
Performance figures
Power 500 bhp / 373 KW @ 6200 rpm
Torque 657 Nm / 485 ft lbs @ 4800 rpm
BHP/Liter 71 bhp / liter
Power to weight ratio 0.35 bhp / kg
Top Speed N/A
7 liter motor pushing 505 at the crank at 6200 RPMS Displacement is a 427 let me say that again 427. Shelby's displacement 330? Making 500 horses at 3500 rpms? Im just wondering other then the weight factor how doesn't the shelby size up? They both go for 80k they both make 500 horse's and the cobra has a smaller displacement. 427 vs 330. I just want to know your views.
Body
Construction Unitized welded steel body, aluminum hood
SHELBY GT500
Engine
Type V-8
Manufacturing location Romeo, Michigan
Configuration Iron Block and Aluminum Heads
Intake manifold Cast-aluminum with screw-type supercharger and air-to-water intercooler
Exhaust manifold Cast iron
Crankshaft Forged steel
Throttle body Dual 55 mm, electronic
Valvetrain DOHC, 4 valves per cylinder
Valve diameter Intake: 37.0 mm
Exhaust: 32.0 mm
Pistons Forged aluminum
Connecting rods Cracked forged steel I-beams
Ignition Coil-on-plug
Bore x stroke 3.552 x 4.165 in. / 90.22 x 105.8 mm
Displacement 330 cu. in. / 5,409 cc
Horsepower More than 450
Torque 450 lb.-ft
Layout Rear-wheel drive
Transmission
Standard (Type) T-56 6-speed manual
Gear ratios
1st 2.97
2nd 1.78
3rd 1.3
4th 1.0
5th .80
6th .63
Final drive 3.31
Suspension
Front Reverse-L independent MacPherson strut, 34-mm tubular stabilizer bar
Rear Three-link solid axle with coil springs, Panhard rod, 24-mm solid stabilizer bar
Brakes
Type Four wheel power disc
Front Brembo 14-inch vented and cross-drilled disc, four-piston aluminum calipers
Rear Brembo 13-inch vented and cross-drilled disc, two-piston calipers
Wheels and Tires
P255/45R19 tires and 19 x 9.5-in machined aluminum wheels
Exterior
Wheelbase 107.1 in.
Overall length 188 in.
Overall width 73.9 in.
Overall height 55.7 in.
Track width, front/rear 61.9 in. / 62.5 in.
Ground clearance 5.71 in.
Interior
Seating capacity 4 passenger
Headroom
Front row 38.8 in.
Second Row 36.3 in.
Legroom
Front row 42.7 in.
Second row 30.3 in.
Shoulder room
Front row 55.4 in.
Second Row 45.0 in.
Hip room
Front row 53.6 in.
Second row 45.2 in.
Cargo Volume 9.7 cu. ft.
Im not at all knocking the z06. It's a damn fine machine. But Im a man of reality and reality tell me that it has no problem matching up to anything. Info please everyone.
C6 Z06
Numbers built N/A
Body design N/A
Engine LS7 90º V 8
Performance figures
Top Speed N/A
Body
SHELBY GT500
Engine
Type V-8
Exhaust: 32.0 mm
Torque 450 lb.-ft
Transmission
Gear ratios
1st 2.97
2nd 1.78
3rd 1.3
4th 1.0
5th .80
6th .63
Final drive 3.31
Suspension
Brakes
Wheels and Tires
Exterior
Wheelbase 107.1 in.
Interior
Headroom
Front row 38.8 in.
Second Row 36.3 in.
Legroom
Front row 42.7 in.
Second row 30.3 in.
Shoulder room
Front row 55.4 in.
Second Row 45.0 in.
Hip room
Front row 53.6 in.
Second row 45.2 in.
