Orange 94 Supercharged V6 Dyno Result
Orange 94
Alberta Canada
Well I finally have numbers!
Setup:
4.2 v6 (1998 F-150)
M112 Supercharger w/2.93 pulley
SSM adapter Plate
Mild ported split port heads and intake
Comp Cams 259HR115 cam
Comp Cams 26918 valve springs
Scorpion 1.73 roller rockers
Lightning 90mm MAF
C&L boost pipe
Walbro 255lph pump
Cobra Blue 39lb injectors
94 3.8 v6 stock headers
94 3.8 v6 25% underdrive pulleys
Double roller timing chain
Video:
[video=youtube;4y109k-c-x8]https://www.youtube.com/watch?v=4y109k-c-x8[/video]
Shop:
I took my car to Tecmotion owned by Matt in Calgary Alberta.
First, off Matt uses a Mustang Dynamometer (Powerdyne) which seems to be very difficult to produce high number on paper. He figures the number that come out on this dyno are about 14% less than a DynoJet.
If you are wondering about the project car in the video, its a 33? Coupe kit car that is going to be Coyote powered. Can't wait to see the car done!
He also has a Mystic Chrome Terminator with kennebell blower and a extremely mean N/A fox body that runs 9.44? and 0-60 in 1.9?
Problems:
Found a few problems with the car that caused a fuel trim.
1. The Cat(s) are plugged.
2. Oxygen sensors need replacement
Results:
On Mustang Dynamometer
247.8 RWHP
264.4 RWT
As a comparison a stock 3v V8 Mustang does about 225 RWHP on this dyno!
On Dyno-Jet (Estimated by Matt, 14% more)
288.1 RWHP
307.4 RWT
At Flywheel (Estimated by Matt)
330.4 HP
352.5 T
So I'm pretty happy with those numbers! Once I gut the cats (possibly put in resonators depending on sound) and new oxygen sensors I should be able to get pretty close to my 300 rwhp on a normal Dyno.
Musturd
Nice man. , car sounds great under load . That thing would be a Wack load of fun on the street
boston2k4
Charleston SC
that is sweet man! looks super clean under the hood
love this build for sure.
you could always gut what you have now and check the tune again then buy resonators down the road if its to loud, but can you ever be too loud?
the mustang dynos are far more accurate as they load the car down as if its actually driving down the street, what ive been told by my tuner at least.
MustangChris
Aurora, CO
nicely done!!! water meth is next :)
although while you're working on teh exhaust, I'd just do some mac LTs, and re-work the exhaust.. . ... :)
Orange 94
Orange 94
Alberta Canada
Thanks! I'm going to gut the cats and see how it sounds. And yes it can be too loud. It tricky to get a v6 to sound nice... its either nothing or sounds absolutely like shit!
I'm planning on doing the exhaust and then putting the car back on the dyno to see what it'll do. But it should run proper once I fix everything because the computer should adjust the fuel trim on its own.
Yeah the mustang dynos are better to tune for real life condition is what I've been told too.
Water meth is on! It helps soooo much! The car is still running a bit too hot on the high end, he couldnt get the car all the way up before it retarded. I'm thinking once I clear the cats that will help it.
This is an interesting but neat build
Thank you!
That thing sounded mean as **** up there!
Thanks! I think I'll be borrowing my friends go pro to do a pull so you guys can hear it better!
Orange 94
Orange 94
Alberta Canada
awwww yea!!! clean install, man!
Thanks! There's only been one person to even notice it on my car :p
Well there actually only been on person at a car show to correctly identify my whole setup. over 75% of people think its a v8...
jeanfltns01
