PBR Brake Questions
Willis_98GT
DFW Texas
I picked up a set of calipers and rotors the other day and i want to do stainless lines too.. so my question is do i buy 99-04 lines or 94-98 lines?
also are the rotors different, because i found a pretty good deal on 94-98 rotors and i dont want to break a set of 4
Lee12609
rotors are the same.
get the hoses for your car.
all you need is calipers, brackets, pads and brake hose to caliper bolts. the bolts are on all 99+ mustang v6/gt/cobra
W
Willis_98GT
DFW Texas
well american muscle shows a 99-04 stainless front line, and also a 94-98 front stainless line, thats why im confused.
Lee12609
yeah, the difference is very minor, and its the length. the 99+ are about 1" longer IIRC. either will work, but if you're replacing them use the 99+ just to be safe with the extra length.
Addermk2
By caliper bolts, im sure he means the banjo bolts.. they have a different thread. Just wanted to clarify.
Lee12609
banjo bolts is what i meant, most people dont know the right name so i said "brake hose to caliper bolts". you're absolutely right.
vermilion
maryland
i had this same issue. i went to napa and picked up 10mx1.5mm thread pitch. 83166 part number. almost 4$ each.
Lee12609
nobody has mentioned a problem. i told him about the different banjo bolts in the first response.
vermilion
maryland
i know. maybe i interjected wrong. i am getting parts together for the same thing. figured i'd help. as far as stainless lines awhile back i picked up some 99-04 russell SS lines from summit i know there longer but not an issue.
This thread rules, read it.
sn95forums.com/index.php/topic,54661.0.html
Mustanger
Southern Oregon
I already have Russel SS lines on all four wheels for my 94 GT brakes but am just about to install the new Bullitt/Cobra PBR brakes & it looks like I can reuse the SS brake lines!! That saves a few bucks...just need the new Banjo Bolts! Thanks!
