pi head or entire engine swap??
CBurt
Springfield, MO
I believe my stock 96 gt has a blown head gasket. Was just wondering everyones opinion on whether I should just do the head swap or if its just as easy swap in a pick-npull motor. Im looking to go pi either way..
D3VST8R96GT
Marble Fall, AZ
Its 10x easier to me to pull a motor then to do ahead swap in the car.... that is why I did full pi motors on both my cars the first go round
C
CBurt
Springfield, MO
Yea I figured the whole package would be easier then a head swap. The plan o s to keep the pi engine stock and just drive as is tand rebuild and boost the original npi
96blak54
Staff member
Lawrenceburg Kentucky
YEA! ....good idea! Deck the block .020" after getting it bored and slap npi heads with modified exhaust ports, decked .080", pi cams, ....it'll run!!!
GEORGEKLASS
Montreal
Why not just run PI heads if going through the trouble of rebuilding a motor?
96blak54
Staff member
Oh...lol. I thought you had a good idea why.
Unless you aquire the newer 9thread sparkplug heads, forget about swapping. Them heads are upper $400 or you can timesert a set for the same price. Next option, basically free npi heads but there is a little work to be comparable and $100set for decking.
I agree swapping pi is the easiest, but be careful with the year selection. Npi has been proven to be comparable to pi many times.
