PI Head swap and cam advice
slo97
Ok i just bought a complete set of pi heads and i wanna get them cleaned up not a full out port but just get the roughness cleaned up and i wanna install a set of cams im liking the comp 270 so far i just want recommendations ill have a full bolt on car, 5 speed, 4.10 gears and later down the road a 100 shot. I just wanna get the top end swapped to a pi. Is this a good cam i go to the track every weekend and this is my dd.
duff daddy
270's are good, made me 300+ at the wheels and led me to a 12.6 ET last year. Good luck
slo97
what other mods did u have ill have a 75mm accufab tb and plenum, long tubes, of course the pi swap and 270's pretty much all bolts on minus udp, but i have the ac deleted and run a shorter belt and ill have a dyno tune what numbers do u think ill make just curious
duff daddy
Underdrive pullies, bbk shorties, jlt, frpp 70mm tb, trick flow 75mm upper plenum, bbk off road h pipe, stock pi manifold... I think that was about it. It put the power though drag radials.
Jrgunn5150
270's are great since you can find them used for like 300 bucks, I wouldnt buy them new though.
