pi intake installed, some questions
nesqwick_05
so i got it on there, istead of useing the lower coolant tube i used 5/8ths heater hose (3ft) and broke one of the intake bolts from over torquing it. my question is y is it smoking after warm up? its not terrible but its smoking regardless, the smoke is white colored and doesnt start right away. any ideas? car runs strong regardless, only got on it 2 times on my drive around the block, no leaking coolant or anything, but it pulled hard enough to spin the bfgs DRs all the way through second ;).
carramrod98
when i first bought my car it smoked, because the coolent crossover was cracked. I think that some pi intakes still come with the plastic crossover, and the extremely hot temps of the coolent can crack it and as the car warms up some coolent will drip onto the heads and burn. It wont happen at idle, but when i used to rev at high r's i would get a white smoke from under the hood. I didnt find out it was the crossover untill i noticed the coolent was low.
its a very slow leak and it took a good weak and a half to be noticable.
if thats the case, the replacement shoudl be free.
if you have the aluminum crossover, everything i just said in useless lol.
Also: do u have pi heads? caseu i hear you can put a pi intake on npi heads, and then have the heads ported for better horse power than than pi intake and pi heads together.
reivaxtorres
maybe you spilled some coolant on the headers or in the valley between the cylinders, that would cause the smoke.
for the bolt that snapped, which one is it? if its any of the ones that go around or near the coolant passages, it might cause a leak and thats where the smoke might be coming from as well.
what gaskets did you use, NPI or PI?
N
nesqwick_05
pi gaskets, and its the one right behind where the T-stat is, the car is smoking from the exhaust pipes, it might just be because its cold though...
reivaxtorres
i would get that bolt replaced ASAP. that bolt would cause the coolant passages not to seal properly (expecially under high pressure times) and that could be where its leaking onto the exhaust manifolds from (leaking from here and finding its way to the exhaust pipes)
or do you mean its smoking out of the tail pipes?
N
nesqwick_05
smoking out the exhaust pipes, there isnt any coolant leaking to be seen under the manifold, or elsewhere, but there is smoke coming out of the tailpipes, like i said it might just be cold, but the car runs damn good now...
N
nesqwick_05
wat bad thing is gunna happen? i spent along ass time putting this on this time, trying to be very careful, i dont wanna go back and do it again...
scarface
Guest
well, if you are burning coolant, I dont think I would continue to drive it. But hey, its your car.
N
nesqwick_05
overflow is staying full... im just looking for the long run consequences, i plan on swaping a 5.4 2v accomadated with a lightning blower next summer, so im not overly stressed about this motor...
scarface
Guest
where are you located NES? if you are near Va, bring it here and I will do it for you free of charge, just so its done.
Steven
SC
for someone who says they don't have alot of free time.. you sure do have alot of.. well uh... time? :hammer:
scarface
Guest
I have plenty of time at home... just hard to get away.
Steven
SC
i'm just messin with you dave lol
N
nesqwick_05
ive done it 7 times, this is the 5th on this car though(had a broken torque wrench and didnt even notice it, had to go rent one from the autoparts store because im a cheapass). im in kansas, not close to va, but its no biggie for me, i do appreciate the offer though. live and learn i guess
killagt
I dont it 4 time and its still smoke like mofo. I ran it hot and bush the HG, but I throw in a bottle of HG repairt and every thing went fine now. knock on wood.
N
nesqwick_05
stoped smoking today, didnt even puff once, maybe it was just the computer day dreaming :angel:...
