pistons
J.T.
I have a 4.6 that I am boring .030 over and I want to know what type or pistons to go with for nitrous. Where should I get the pistons from? Also this is on a budget so as cheap as possible(saving money for bigger cubes).
DropTopPony
South Jersey
Nothing cheap about aftermarket 4.6 pistons...
Manley, Mahle,CP,Diamond are all good brands making them.
Are you going with a high compression nitrous setup?
J
J.T.
I do plan to do nitrous but I dont know what it a good compression for that. I think I remeber hearing anything 10:1 and below for a streetable motor. So are flat top pistons to high? and what will the compression be after that?
jfor441
Flat top pistons and PI heads will be 12.5:1 Compression. It is streetable but you have to crank the timing down for street use.
With NPI heads you will be around 11.:1 compression which you should be able to run no problem on 93 octane fuel.
J
J.T.
Awsome i will keep my npi pride! :banana: But now the question is does anyone have some pistons for sale?
jfor441
If you are gonna be spraying I would recommend getting forged rods also. You probably won't find any .030 pistons for sale. You gonna have to buy them new.
Zwolaver21
I have a set of brand new manley flat top pistons with rings that are for sale. I will let them go for 600+ shipping you wont get a better deal than that for some brand new stuff.
Jrgunn5150
Why are your boring it .030 over? 11:1 will run fine on the street, but you will want good rod's and bolt's as well.
:hammer: There's nothing cheap about aftermarket 4.6, period, lol
J
J.T.
true that. that is why I am going to build another pushrod motor after this 4.6 runs.
voidfinger
yea a 11:1 cr nitros set up would be killer.. but get that 11:1 threw a pi head... don't waist time and money on the npi stuff... trust me.
J
J.T.
I have already done a lot of work to my heads (all my self, little money spent), and I am not really planning on spending too too much on this motor because I know that 2v are dogs. I just want to get some pistons and put a good squeeze on it and call it a day.
G
GREG@SN95
Guest
most people bore them .20 over. Thin sidewalls...
idk much about mod motors... but I'm surprised no one has said that.
J
J.T.
Yah I think I have changed my mind on that I dont think I am going to bore it.
voidfinger
I've heard that a 2o over would unshroud the valves and make a bit more power... not 100% though.
Jrgunn5150
Anything over always unshrouds the valves, not enough to matter though. bore as little as you can.
