Power estimates for my car blown
justinschmidt1
What kind of power do you guys think my car will put down with the current setup plus a p600 procharger and a 2 core intercooler.
The bolt ons in my sig + 10-12 psi, 42lb injectors, fuel pump, 90 maf, and dyno tune.
I would say my car puts down atleast what a stock 99-04 stang puts down....102 trap speed= 230-240 whp? I dont know
i want to be over 350 to the wheels
Jrgunn5150
P600B have belt shredding issues, I wouldn't push one, find a cheap Vortech if you can.
But, that should get you over 350, or close. Get the PI cams at the same time and you'll be nearer to 400.
Of course some car's are weird, so don't come to me for a refund if it pulls 300 rwhp, lol
J
justinschmidt1
what do you mean by "push" one?
dont run a lot of boost?
What would be a good amount of boost to run?
97stanger
almost same mods but with a vortech here. 370rwhp, 380tq. thats with stock non pi heads/cams too
Steven
SC
i'd hope high 300s with PI cams. I'll be doing the same route one of these days.. gonna install cams with a stall speed first, no sense in forcing air into a bad breathing motor :ass3:
J
justinschmidt1
What kind of boost you running? 10psi?
Yes nes, I got it from erich.
nesqwick_05
i believe blown97stanger is running 12lbs
and your lucky...if i woulda kept my stang it was gunna be my next investment :naughty:
J
justinschmidt1
so is 12 psi safe?...This is my daily driver so I dont want to blow it up.
Yea, it was such a good deal I couldnt pass it up...still gotta save up for injectors, fuel pump, 90 mm maf, and a tune.
Jrgunn5150
The une and fuel system will be what makes it safe.
Jrgunn5150
You would basically want timing pulled, if you have an Xcal you can do that yourself. If you are going to switch boost alot (It's kind of a pain to do ), then you might want different tunes.
I ran 10.3:1 with 10 PSI, I just kept it kinda on the ridiculous side of safe, 12:1 A/F, 18 degrees of timing. You leave power that way, but you keep your rods internal rather than external also.
nesqwick_05
id bolt it on with a new pump and run it as is(fmu, its what its there for) until you can afford the rest. its what erich and i both did, never had an issue.
