power pipe help
Lebedin8654
I am putting a power pipe on my car how do i run the bypass valve. its on a Strim on my 94gt
LAFENATU
good powerpipes have a provision for it... look at the ones on andersons site
95 svt cobra
OK, well you should have a plastic bung on your PP thats threaded into it and a hose runs off that to your bypass valve, then you should have another hose coming off your discharge pipe that is connected to the molded bung opening (assuming you have the plastic discharge pipe.) All that hooks together in one giant L with your bypass being right in the middle, then if your running a BTM you hook the vacuum line from the top of your bypass valve to the vacuum port on your BTM box. Or you can just tie it in to the vacuum lines running to your FPR or intake. So long as its the 1/8 line i believe. lemme know if you need further clarification, i have pics somewhere. And do yourself a favor and make sure your opening that you cut in the fenderwell is well measured, it can be a whore to get in place if its not and it will save you some scrapes.
L
Lebedin8654
Some pics would be great. i think i have a good idea of what you are saying. my pipe is missing the plastic bung that threads into the into it thats where i was lost. thanks
95 svt cobra
Ahh yeah, you can go to homedepot's plumbing section and buy one, i got mine there i cannot remember what size it was. But its like 4 bucks, ill find some pics and post them up later, im startin the BBQ pit and cracking a cold one so ill probably forget lol
L
Lebedin8654
These are the pipe that i am changing. i got a pretty good idea about it!!!
[attachment deleted by admin]
LAFENATU
What the hell is that thing??
Why didn't you just buy an AFM pipe??
