voidfinger said:
well i can smell it... I put plugs in it thinking that was it. The wires are about 5 months old. I had that problem before kinda and it was the wires breaking down. But i dought that ford wires will break down that fast exspecially since i had the stock ones for like 100k. Anyway, how do you check the fuel pressure on a 98 ? It doesn't have a regulator? also, the thing is getting bad gas milage.
we do have a fuel pressure regulator, its on the passanger side fuel rail. its part of the rail and cant be removed, so thats why they only sell them for 96/97 models.
you can check the fuel pressure by looking up a pressure reader (cant remember what its called) on the shrader valve on the passanger side fuel rail (or the drivers side, but im pretty sure its on the passanger side). hook it up there and it will tell you if its getting enough pressure.
when was the last time you changed the fuel filter? if its been awhile, it could be that its dirty and/or clogged and not letting enough gas go thru.
or it could also be bad gas. go fill up with some 91/3 octane from 76 or mobil.
