96TANGERINEGT
- Joined
- Sep 21, 2011
- Messages
- 2,704
- Reaction score
- 204
So in the market to get tunner . Any suggestions on what brand should be helpful
What are you trying to do exactly? SCT is an awesome programmer.
I do have a Ford ids scan tool from work I can use I can flash from thatI am thinking of one as well. Correct me if Im wrong but the SCT programmer will take you pretty far with the intake work. The programmer promises 20HP gains at 93OCT by itself if I am not mistaken. I think its when you get into forced induction that you need a dyno tune. If your on a budget could go with a eliminator chip but you cant read engine codes and you have to send the chip back to get it reflashed. Hope this helps!
If you plan on ever modding to the point of needing a tune, cams, blower, nos, etc look and see what the tuner in your area uses, sct vs diablosport. Id recommend a sct handheld, like the xcal 3. More common than diablosport. Do not believe the advertised 20hp gains though, even on 93 oct. But like you said with the pi intake, maybe 25+- Also Id say the money for throttle body and plenum would be better spent on gears if you don't have gears already. Good luck!
what she said lolSCT x-cail 3!
I am sure the car has stock gears . I can pull about 70 out of second gear . What is good for these cars my old fox had 4.30's in it . Any advise I am a new 4.6 owner this forign to me . Lol .
