Oh.... You are miles ahead of most of our builds!
Blak, you might eat this up bro! So close but so far. Ive been compiling parts now for 3-4 years. All my work was performed by a $200 dremel, with every type of tungsten carbide 1/8 bits (about 30 of them). Couple of pics of my heads. I've done slight work to my Chambers, my bore is +.020", lifter bumb taken out, no high or low spots in the porting. My chambers are 45CC's exactly with spark plugs installed. I measured out on the deck surface exactly how far I brung out chamber process, I kept the same angle (using a compass and protractor) at which the heart side of the chamber set back from the valve, used a piece of special made wood (set at same angle as heads) to lay my dremel in as a cradle. Kinda like somone would use a wood lathe, and thats how I achieved the angle and space. It took a while to get the wood just right, its more important than your heads really. I will give more detail on these later.Oh.... You are miles ahead of most of our builds!
Ive always checked out your stuff, i find it very interesting, especially the camshaft specs. I'm a nerd for cam specs, it took me a year to pic out the ones I have.Looks like fine work to me! Heck.. anything for the pursuit of performance!
I believe you are on the right track! As with anyone that "tries"! We all on the right track!
Take my 18:1 static compression build. It would have been successful if the 2nd ring was fitted correctly and the pistons were purposely made for ethanol! I keep saying ill adventure back to the build someday. Ttocs keeps on me about it....itll happen again one day.
But my point is, keep trying different avenues, learn from it. Keep building!
Your going to laugh at this one, I don't even have 2 cams done and I'm trying to add 2 more. Cliche I know, but it was woman owned, suspension went bad, and she bought a newer ford. Has 105K miles. I just wanted the Teksid, and maybe save the rear for an old ford truck one day.Get’er done!!!!!!!! [emoji38]
That's exactly what I told my girlfriend that was living with me and complaining about everythingThe garage is a little piece of heaven.View attachment 3872
next time she is bitching just mention that if she leaves it is all you will have, and that is fine.....That's exactly what I told my girlfriend that was living with me and complaining about everything
I rather be out in the garage like heaven
I'm going to have to download that one, best meme yet.
