Project NoPulp - V2
50HSN95
Minnesota
Bummer on the Coyote swap, but nice having a house though I bet. The shop on the house looks pretty cool also! Hate it when real life gets in the way of hot rod projects :).
Those SVE wheels are really cool looking, I like the looks of them.
Orange 94
Orange 94
Alberta Canada
Been busy... crazy busy with work and now I'm also trying to build a detached garage. Fun Fun Fun!
Second engine wasn't the best. It was bored 60 over, not desirable - also the crank was not in great shape. Not blaming seller, but disappointed in the quality of the reman. So taking the good parts off that engine and going back to the first engine.
Good news was that it had a more aggressive cam than what the seller told me it had :)
IMG_20200105_130707 by Richard Brown, on Flickr
I've received pretty much every part I need. I've been busy cleaning everything up - smoothing/mild porting the intake and heads.
IMG_20200105_130711 by Richard Brown, on Flickr
IMG_20200222_092010 by Richard Brown, on Flickr
IMG_20200222_092024 by Richard Brown, on Flickr
IMG_20200222_091944 by Richard Brown, on Flickr
I'm using the trickflow SN95 elbow. Anyone wondering on fitment on the explorer intake, i did need to do a few modification. I'd like to give trickflow the benefit of the doubt on fitment for their application, but this also isn't an uncommon setup...
First, the finish inside the elbow wasn't ideal. For a "made in USA" product, it seemed more china made looking. So I smoothed that out.
IMG_20200222_100623 by Richard Brown, on Flickr
IMG_20200222_100632 by Richard Brown, on Flickr
IMG_20200222_103941 by Richard Brown, on Flickr
Second, the hardware included was only studs for the throttle body side. I had to pull the studs from my old intake and install them on the new one. When I put the elbow on there was no was a nut was going to fit on the top left... so I had to grind a good chunk off. I'm assuming trickflow has special hardware included on their intake? I don't know there was done of material there, no need to have it so tight.
The bottom right stud is also a bit too long - it doesn't interfere, but this nut will need to go on first.
IMG_20200222_112827 by Richard Brown, on Flickr
IMG_20200222_112841 by Richard Brown, on Flickr
IMG_20200222_114125 by Richard Brown, on Flickr
IMG_20200222_112823 by Richard Brown, on Flickr
Overall it will work and looks good.
IMG_20200222_103955 by Richard Brown, on Flickr
Done making a mess now. Did a final clean of the shop and once I do a final clean of the parts assembly will begin!!
IMG_20200222_124155 by Richard Brown, on Flickr
Orange 94
Orange 94
Alberta Canada
Been awhile, but making progress around work and other projects.
00100dPORTRAIT_00100_BURST20200502134311518_COVER by Richard Brown, on Flickr
Stock bottom end.
IMG_20200503_100404 by Richard Brown, on Flickr
IMG_20200503_105212 by Richard Brown, on Flickr
Installed Canton windage tray with Ford performance oil pan. The windage tray took more modification to make work than I would have liked for the price point, but it worked well.
IMG_20200503_105128 by Richard Brown, on Flickr
IMG_20200503_105138 by Richard Brown, on Flickr
Ford Performance E cam and stewart high flow water pump
IMG_20200503_123813 by Richard Brown, on Flickr
Orange 94
Orange 94
Alberta Canada
Ford performance aluminium heads with comp cams springs, roller rockers and push rods.
00100dPORTRAIT_00100_BURST20200516102117149_COVER by Richard Brown, on Flickr
00100dPORTRAIT_00100_BURST20200516114213223_COVER by Richard Brown, on Flickr
00100dPORTRAIT_00100_BURST20200516114221751_COVER by Richard Brown, on Flickr
Using explorer intake - i like the look at its the best value. One of the best ford made intakes and close to even the aftermarket performance at junk yard prices.
00100dPORTRAIT_00100_BURST20200518104340136_COVER by Richard Brown, on Flickr
IMG_20200518_113420 by Richard Brown, on Flickr
Old Ford Blue
IMG_20200518_122723 by Richard Brown, on Flickr
00100dPORTRAIT_00100_BURST20200518144609986_COVER by Richard Brown, on Flickr
Orange 94
Orange 94
Alberta Canada
Painted the T5 as well, along with BBK 75mm throttle body and alternator I took apart.
00100dPORTRAIT_00100_BURST20200524121051975_COVER by Richard Brown, on Flickr
IMG_20200524_142842 by Richard Brown, on Flickr
IMG_20200524_142511 by Richard Brown, on Flickr
Test fit Steed Tri Ax and Like Wise shifter.
00100dPORTRAIT_00100_BURST20200524141803236_COVER by Richard Brown, on Flickr
00100dPORTRAIT_00100_BURST20200524141754684_COVER by Richard Brown, on Flickr
I'm also building a new detached garage now. The concrete just got poured, so I'll be starting construction soon. Thinking I'll finish the garage before the car.
