Prostars
SoTxKnight
I am planning on ordering some Weld Prostars for the front
What size is common and what is the back spacing and bolt pattern?
I had bought some 15"x10" from a guy a while back and well finally decided to get the skinnys upfront. I believe most run a 15"x4" or something like that. Also where is a cheap place to pic them up. Would I need a spacer aswell so they dont sit inside the fender so much?
What set ups do you all have? Pics if you got them...
duff daddy
15x4's i run the MM Hubcentric spacer up front i think it s 7/8's with 1/2 on 20 blow though lug nuts with 3" studs (should really have 3.5's up front. bolt pattern is 5x4.5.... and I run 8's out back, nothing more is needed unless you have massive power....
I have more pics if needed.
SoTxKnight
you lost me with that part. 20 what?
Do you run the 15x4 all the time or do you have other rims for street use?
Pics are always welcomed aswell.
duff daddy
Staff online
