prothane trans mount =s vibrarion
96laseredcobra
96laseredcobra
Farmington MO
so shop says it's rear control arm bushings are out. I looked and they're falling apart. we loosened the trans mount , it's a lil better. I have sve tubular control arms so replacement bushings are out. gonna get a new kit. will keep this post up-to-date
96laseredcobra
96laseredcobra
Farmington MO
first pic is what mine look like, second pic is replacement bushings.
Staff member
The problem with those cheap control arms is that they are not built very strong. Also, having poly bushings on the both sides of the control arm will cause it to bind. Im not surprised these bushings went out, and youll probably end up replacing these things every so often until you change those control arms.
DKblue98GT
I never considered what other parts you might have. I know it's more money but I would recommend Something like MM lowers with spherical bushings on one end. Stock uppers are good and you want rubber bushings on the axle side.
SnakeBit!
Florida
how long have they been in? what kind of grease was used to install the originals in them?
96laseredcobra
96laseredcobra
Farmington MO
So is all vibration at speed gone now??
there's still some but nowhere near as much. gonna recheck more tomorrow as the bolts were loose when we started today. so just for safety sake.
tbird462002
Prothane trans mount on a t45 is a horrible idea. If you make enough power and can get it to hook you risk snapping the tailshaft off the trans.
Don't know how much power your making but I'm around 600 at the crank and run the stock mount with zero issues.
Sent from my moto x4 using Tapatalk
96laseredcobra
96laseredcobra
Farmington MO
ended up being the rear pinion gear grinding off teeth of the gears. not my problem anymore though.
