pushrod gurus please come in.
Steven
SC
tooslow said:
Don't explorers use an offset pumpkin? making swapping the rear into a mustang just about impossible.
Vintage mustangs have offset pumpkins. My 9" has two different length axles
modo
Philadelphia, PA
8.8 is two inches longer so you will have to deal with that by cutting or by using a different off set wheel. you will also have to cut all the 8.8 brackets off and make / weld on spring perches since the 8" uses leaf springs. for a cruiser this is a lot of work for no gain
.02
Steven
SC
For most cruisers its really about the good rather then the function. I have a tremec in my car, don't have a drag strip, road course, or any race tracks around. Pretty useless when I could have swapped a T5 in for less but it is what it is.
modo
Philadelphia, PA
good rather then the function?
i assume you think that the 8" is weak? a 8" can be made as strong as a 9" with parts from currie and will be lighter, fit tighter, and would have the correct pinion angle / instant center since the mounting points would be in the factory location not welded on by some dude in the driveway not using a jig. there is nothing wrong with a 8".
vermilion
vermilion
maryland
I swould like a 3.73 gear ratio. Not looking to launch it.so the 8 is more financially practical. I think ill tackle the body work 1st but ik am entertaining good ideas.
Steven
SC
I have a 65 resto-mod coupe with a posi 8" in it. I know what they can take. Never said one bad thing about them. I also own my 70 mach 1 with a built 9". Each have pros and cons. What I meant to say earlier is its about the "goods" rather then complete use of whatever your doing to it. Very few cars take any particular part to there potential. Most of the modifying that gets done on a car these days is simply for the wow factor, or just something to do. Just depends on what you want to do with the car.
modo
Philadelphia, PA
8" would be a 3.80. ratech makes a complete bearing / race kit for it for less then 100 bucks. if you want a strong lightweight carrier / center section look at the currie alumi8
modo
Philadelphia, PA
66 in my sig makes a tad shy of 400 through a 8", my 93 has made over 800 and has nothing fancy in the 8.8. i am well aware of needs vs wants
Steven
SC
I had an 82 coupe race car a couple years ago that was running just a plain jane 8.8 with mini spool and 4.56's. Stock axles. I never had a problem with it either. I was never knocking any of the rear ends. Unless its the F-body style 10 bolts, you rarely see a factory rear end exploding on any domestic cars.
tooslow
thanks for the clarification
Steven
SC
No problem. It was highly confusing when I changed the axle setup around and saw the different lengths. Threw me off
modo
Philadelphia, PA
rear width are not the same for each year or model car
8" mustang
65-66 52.25"
67-70 is 54.25"
71 is 56"
74 it went back to 52.25 and from 5 lug to 4
9" for a swap
60 tbird 52.75"
57 ford 52.25"
1975-80 Granada 52.25"
