Pushrod length
Venomized
Iowa
I just used my pushrod measuring tool to measure the pushrod length needed for my set up and measuring it according to this:
If my calculations/research is correct that piece will give you the correct range of measurement. Just to be sure, measure one of your current pushrods and that measurement should be somewhere near the middle range of the length checker you get.
Once you have that, here's how it goes:
1. Put the cylinder to TDC on it's compression stroke
2. Torque the rocker arm nut/bolt to where it's supposed to be (~20ft#s usually) with the length checker where the pushrod goes adjusted to it's minimum length.
3. Expand the length checker gently until it contacts both the rocker arm and the lifter (make sure it's in the cups where it's supposed to be) Don't unscrew it with enough force to compress the lifter, just enough to just produce 0 lash.
4. Unbolt the rocker arm and remove the pushrod length checker, which was adjusted to the length required to produce 0 lash.
5. You will need 8" calipers for this: Measure the length of the pushrod length checker. Write this down and add .020" to that number, then add .060" to the original number. These 2 numbers are the range of length your pushrods need to be.
The number i came up with is 6.240. If i add .020 to it (6.240+.020) its 6.260 and if I add .060 to it (6.240+.060) its 6.300. Now the pushrods I ordered were supposed to be 6.272 and they actually measured out to 6.250 so I sent the seller (ebay) a message demanding they fix the problem. The set I ordered was the FMS-6565-L302 set which is hardened and 6.272. So if they were correct I would be able to use them and have correct geometry correct?
i marked the top of my valves with a sharpie and looked at the pattern the rocker head takes across the top of the valve. it supposed to go right across the middle. are you using a solid lifter to test this?
Venomized
Venomized
Iowa
I'm not using a solid lifter, I don't own one. I used the FRPP lifters I have in the lifter bores.
det_riot
Dearborn
do you have extra lifters? you can make a solid lifter out of an old hydraulic lifter
if you're not checking pushrod length with a solid lifter than you're wasting your time, hydraulic lifters will compress when they don't have oil pressure.
Venomized
Venomized
Iowa
Thats a good write up there but in the write up i found and quoted up top, you just unscrew the adj. pushrod until you have zero lash, since the rockers already torqued down, you go far enough that it does not compress your lifter at all. Then you add .020" to .060" for lifter preload and thats your PR length you need.
Venomized
Venomized
Iowa
I then adjusted the pushrod to 6.300" and tightened it down and did the marker test and Im riding directly on the centerline of the valve.
Wanted to specify that when i did the check for marker test I only tightened it 1/2 turn past zero lash.
