Quarter-Door-Fender Clearance ? Sn95 Cars
colormebad
What is the normal rule of thumb gap, between door & quarter and front of door and fender ? Sn95 mustangs
db281gt
MD
Yea basically try to just get it pretty even . Keep in mind it's a mustang and there is only so much you can do. The build quality is ok but you will prob will not be able to get everything 100% . It's just the way there made
C
colormebad
My pass side looks wayy better..But drivers side looks good, door to quarter...But front door to fender has alot bigger gap...I would have to set the clip behind the fender where the 2 clip/bolts are, on the other side on the mounting clip, closer to the door , to narrow the gap...But the i would have to take the other fender & hood back some also to match...OR! Bring the driver door forward some
there's not a whole lot of adjustment in the SN95's body... i suggest bolting the door on so the gap is where you like it on the rear 1/4, then bolt the front fender to match best you can.
C
colormebad
I had that backwards, its the driver that has a bigger gap between front of door and fender...Before i replaced the new door pins , the same door had a bigger gap between quarter/door...I think something was off from the factory on that side...Bringing that door forward is the onlything i see to do...
whiplash473
Northern IL
id move the door forward and if you cant get it exactly where you need then move the fender back to compensate
C
colormebad
Im starting back on it tomorrow...Just trying to get it ready for some grudge races comin up....Thanks
