Question about mass air sensor??
floyd4ford
I bought 30lb injectors and a c&l calibrated for them. I want to know if I can just unscrew the factory sensor and put it on the c&l and will it work correctly??
scarface
Guest
My C&L kit required me to use the factory sensor..Ive always heard the ECU is what is calabrated, not the sensor.
NYC94GT
The sensor will I think, but you need to fool it with the right sample tube...
2slo95fiveoh
Lawrence, Kansas
if you have the mass air housing and the 30lb injector tube then your factory sensor will work fine. my advice is after you unscrew your
factory sensor then take some mass air cleaner (any parts store) and spray the small silver tips to clean them off. then you should be
good to go O0
