question
SN95_DropTop
okay so i need some help guys. i was thinking of getting my stock block bored out .030 how reliable would this be now take in note that it would be kind of a daily driver and it would see some drag time not a lot but some also im not trying to build a a all out drag car yet ;) . im just trying to get something like 300 to the wheels anything more would be great that now for second question is what would the block bored out with good h/c/i do to the wheels would that at least hit 300
NYC94GT
You can pull 300rwhp from the stock block w/o boring. Get a good set of Heads, cam, intake, full exhaust and run a 75 shot Squeeze and you be over the 300 mark. For safety, run a bottom end main bolt support.
scarface
Guest
you can be close to 300 by just doing the Pi head swap.
Paul
Boring it .030 and having the rest of the machinework checked (align hone mains, deck, etc...) definitely won't hurt anything on a daily driver. Don't forget you'll need new pistons, your rods will need to be resized, and the crank could probably use polishing.
As for a 300+ rwhp, I would say:
AFR 185s
Systemax II, 70 or 75mm TB
Bigger comp cam or just call Ed Curtis and have him cut you one
Longtubes
Full exhaust
30 or 36 lb injectors, MAF
Pro Magnum Rockers
Good new lifters, pushrods
etc. etc...
That will easily put you well above 300 rwhp with the right cam.
Paul.
Paul
scarface said:
DOH :comando: :slap: I forgot those things were still around :ass3:
You don't remember them? Remember, waaaay back a long time ago when Ford produced a motor that didn't suck. ???
scarface
Guest
You never fail to make me laugh at least once a day bud O0
NYC94GT
AFR 185s
Longtubes
Full exhaust
Pro Magnum Rockers
etc. etc...
Paul.
Dude, don't forget he's talking about a stock factory 5.0 block. They are weak around the cyl's and boring is not really a receipe for strength.
SN95_DropTop
okay guys im getting mixed reviews on my plan from diffrent people not just in the forum from everybody i speak with what would you guys recomend me to do keep in mine that im california so it has to be street legal and its kind of a daily driver so just hitting 300 would be cool with me :banana:
Paul
Dude, the block will break when the main webbing, lifter valley, and front side let go. NOT because the cylinder walls are too thin.
In that case, just buy a HCI kit from Edelbrock/TFS/whatever that has a CARB sticker and be done with it.
Paul.
Late4Work
If ur lookin for 300rwhp, u better watch ur block cause it may crack if u ride it hard
Paul
I swear there are a bunch of people on this board who just make "tech" up as they go along.
copo123
