just did an engine swap from a 96' mustang gt and put in a 01' bullitt. i used the wiring harness from the gt. when hooking up the alternater, i noticed that there was a small wire that would usaully plug into the alternater on the gt but on the bullitt there is no where to put it. anyone know what this is for? also, on the gt there is 2 plugs for the temp sensor, on the bullitt there is only 1 and i cant find where the other plug should go. how do i get the temp gauge to work thanks
i dont know about the alternator...but for the other sensor, you can either find a spot in the block or just use a y-fitting in the one sensor spot.
