quick questions....
SLOW95GTS
I'm gonna be doing an h/i on my 95 this summer and have a couple question because i've only done them on foxbody stangs..
so first off, Do i need a computer tune if i run aluminum heads and a cobra intake without an aftermarket cam?
second, Should i run a cobra ecu to run 24lb. injectors? or just get a maf calibrated for 24lb injectors?
and lastly how street-able is the steeda # 19 cam if i decide to put it in without a tune?
thanks in advanced.
the5.ohh
Shaolin, NY
thanks in advanced.
I don't think you'd have to get a tune with just changing the heads and intake manifold, add a cam and your gonna need a cam. From what I've read up, the Steeda #19 cam was specifically made for the bastard 94-95 5.0s with the picky computer. You can get a calibrated MAF for 24lb injectors, I don't think you need to swap to a Cobra ecu unless you need it. The Steeda #19 works well on the 94-95 5.0s, not 100% sure if you'll need a tune with it though. If i was doing H/C/I I'd only do the Steeda #19 since they're really compatible with our ecu's.
96GTPlanB
