Radiator hose keeps blowing off
SC-96gt
Ive got a 1996 mustang gt and the other day i was driving and gunned it through a turn and blew a hole in my heater hose. We replaced it and now when i throw it into 2nd the hose just shoots off spilling all my coolant...what can i do to fix this
SC-96gt
I'm using the the clamp that came with it and you cant tighten it anymore
Paul
You have way too much pressure in the system if you're blowing hoses off. I wonder if you have a blockage/restriction somewhere that is causing the excess pressure? Which hose are you blowing off, the upper or lower?
SC-96gt
umm idk there are 2 right next to each other and if your looking at from the front its the one farthest to the left
94Pro-5.0
Little Elm, TX
so its the smaller 5/8" hose going from your water pump to your heater, or the hose coming from the thermostat?
Stangbangin
is it running hotter than usual>? maybe airpockets in the system...did you purge the system when filling it back up with coolant? I usually let it run for about 15 minutes or so to push all the air bubbles out of the system. I dunno if this would lead to you blowing hoses though.
sonicsn95
Just guessing by your name that you have a supercharger, you might be pressurising the coolant system some how. There might be a intake gasket leak letting boost pressure into the coolant system. :dunno:
Mr. OAM
The factory hose clamp is a single use design. It is not made to be opened up and then to hold tightly again. Buy a wormgear clamp and tighten that sucker down.
Steve
