Rattling sound from gearbox area
Adam Vinnicombe
Hi all I'm new to this forum stuff so hopefully I'm posting in the correct area?
I have a 2001 ford mustang GT with 46,000 miles on the clock and it's developed a rather annoying rattle like stones in a tin can. The rattling noise is in any gear and it starts at around 2,000 rpm BUT only when crusing or very very light throttle. If I accelerate with 1/4 throttle or more the rattling sound is not there its only when you feather the throttle. The engine pulls strong, no smoke, no rattling sound when in neutral. Also when in neutral you can not reproduce the sound it's only when in any gear and driving. Now when the rattling starts I have held that rpm steady and slowly pressed the clutch in and as the clutch goes down the rattling gets weaker until the clutch is disengaged and the noise stops.
Any ideas on what could be going on?
I did take it to a garage and they charged me £170 just for them to say "I have now I deal mate, could be chain slap" but I don't think it's that cause I can't get it to reproduce the stones in a tin sound when in neutral.
Many thanks
Adam
Paladin1001
Check your transmission mount. Mine is bad and it is making a weird noise. I only found it because I was looking into my clutch being hard to operate. My mount is broken completely through and it makes a weird noise like you describe.
Silver95bird
also check all the heat shields on all of the cats. they sometimes come loose and rattle around like crazy.
Sent from my moto z3 using Tapatalk
I just replaced a cat because it was broken and rattling like a mofo. If you got down under the car while it was running you could tell where it was coming from.
Adam Vinnicombe
Adam Vinnicombe
Unfortunately I don't have any cats fitted. I've checked all the exhaust heat shields.
Can it be chain slap, piston slap or a bearing gone?
Like I said at the moment it only happens when in gear and only under light throttle opening. When your accelerating at any pace there is no noise also if you come off the throttle there is no noise it's only when you try and hold a steady speed
Silver95bird
chain slap, piston slap, bearings.... if say maybe if it was 146,000 miles and not 46,000 miles. not likely. chains at maybe 150k. unless this car was run without oil. a lot.
the other bad exhaust rattle i found was around the hangers and where the pipes go over the rear axle.
and maybe a leak where they decided to put that stupid gasket in the passenger side at the manifold, but thats not a rattle noise.
Adam Vinnicombe
Adam Vinnicombe
The noise is definitely coming from under my feet. Had the hole exhaust system checked out when I had the new O2 sensors fitted.
A little update. I took the cover of the clutch lever arm and looked inside and found nothing loose BUT with the engine running I found two things. First was the clutch lever is vibrating a lot. Of course it moves back and forth but it can also move up and down and is virbrating around with the engine running. Second is if I depress the clutch everything sound normal but as I allow the clutch pedal up the clutch release level/fork starts to shake and there's a grinding noise in the bell housing. Any ideas?
I have driven the car with the clutch fork cover plate of and the noise is still there but louder
Paladin1001
That is starting to sound like throw out bearing noise. I have read of issues with the throw out bearing with these cars.
Adam Vinnicombe
Adam Vinnicombe
OK I will look into that. Can this be fixed on a driveway using Jack's and axle stands or will the car need to go to a garage?
Silver95bird
look inside the inspection cover and see if the the throwout bearing is at least in one piece. i had one explode on me, luckily i was just going to start the car when it jammed, and then snapped the clutch cable. and of course it was -8* that morning.
cheap autozone chinese junk. i put the ford racing clutch in it, and its been much better.
Adam Vinnicombe
Adam Vinnicombe
It's rpm related and only when there is a light load on the engine as in when you are cruising.
Gearbox mounts are good, the throw out bearing is in one piece BUT when at idle and looking through the fork cover you can hear a clicking sound and when you do the release fork jumps at the same time.
Also this morning I went under the car and grabbed the drive shaft, it does not have any play in the up, down, left or right directions but if I twist it one way then the other it dose make a clonk noise but is this normal and is just taking up the play in the gear teeth?
Adam Vinnicombe
Adam Vinnicombe
F#&k it this happened this morning. I've been having a very bad rattling sound from the gearbox area in any gear at light throttle settings for a while now then this morning thus happened. The car is in neutral and at idle speed, as soon as I push the clutch in the noise stops and comes back the second the clutch pedal is aloud to come up. Please see the video on the link below
RAU03MACH
NEW MEXICO
That sounds like a throw out bearing on the clutch
Mine made that same noise until I replaced it
Adam Vinnicombe
Adam Vinnicombe
Can I drive the car?
Can this be fixed on a driveway?
I have a repair bill for a new clutch witch was done only 4,000 miles ago BUT that was 11 years ago in time when the car was still in the states before it was shipped over to the UK but no mention of any bearings being done
TOB is normally included with the clutch kit. With that being said no matter what brand clutch you get I have been told to only use ford racing TOB when replacing it, even if it has one in the kit.
