Rear axle seals, gears, axles.
Cochise
This is a repost from the drivetrain section... Since it's road racing centric, I thought it wouldn't hurt. Thanks for your input.
I had my first HPDE this weekend with the car, it went really well until my 4th heat. I went to check the brakes to see how much pad I had left, and when I check the rear I noticed the inside barrel of the wheel had oil/grease/fluid of some sort. I fear it was a brake leak but after lifting the car and inspecting it appears that it's most likely the axle seals. Not too big of a deal but obviously it ruined my weekend on track. Now on to the questions and there are plenty!
1. Since I'm going to have the seals/bearings replaced, would this be a good time to replace the axles?
2. If its a good idea to replace the axles? is 31-spline necessary, or is 28-spline sufficient? This is a HPDE/Road coarse car and I won't be any crazy launches on drag slicks, hence my question.
3. The car has 3.73 gears, it was like that when I bought it. I'm contemplating going with 3.55's with a Torsen LSD. Any thoughts on this? I was at Barber MSP this weekend and I feel like 3.55's would be better suited for that course and even more suited for courses like NCM and Road Atlanta.
Future plans for the car, in this order are...
1. Full street/track suspension with PH bar from MM.
2. Coyote swap with T56
3. Eventual aero-kit and body work/paint to make it look, well, nicer. Haha!
95opal
__________________
YES
__________________
______________________________
Why replace ...just upgrade 31 spline.
With the coyote in the future id leave the 3.73 in there
